Entering Multiple Parts - Save
johnmaljaars
Post by johnmaljaars »
When posting multiple parts to EST, each time when entering another part we need to click "save" in order to allow the next part to be entered. Could the program allow for the following sequence 1. type in part number, 2. tab to qty 3. enter qty amount 4. hit enter so that it goes to the next part entry? Or at any point in any of the boxes, hit enter so it goes to new part entry window.
Now when hitting enter, it closes the part entry window and the part window has to be selected again by clicking on "parts" tab. The point being make "enter" work to do multiple part entries without having to use "click" or open parts tab again.
Re: Entering Multiple Parts - Save
Hello,
That behavior isn't going to change because of the 80/20 rule. Enter goes to Done by default because adding a single part tends to occur more often than multiple parts. That being said, it sounds like you're heavy into using the keyboard. Try using Alt+V when you're entered your part information and you'll get where you want to be.
johnmaljaars
GOOD TIP - I DID NOT KNOW THAT OPTION. THANKS.
Return to “Tips + Ideas”
