Discounts On Revisions?
Is anyone working on or even thinking about the ability to add discounts to revisions? Also Alldata allows you to select which items you would like to discount on any given order. It would be nice to be selective when applying discounts.
Re: Discounts On Revisions?
It's been discussed here before. Discounts on revisions is on the enhancement request list. The current thinking is this will best be accomplished when the 'by-the-job' approach is implemented. At last check there was no time frame associated with BTJ. That may have changed.....maybe one of the M1 guys could chime in.salineauto wrote:Is anyone working on or even thinking about the ability to add discounts to revisions? Also Alldata allows you to select which items you would like to discount on any given order. It would be nice to be selective when applying discounts.
BTJ would also allow for selective discounting.
Currently 'Discounts' are calculated on total order dollars, of which Revision items are not part of until transferred. the job container approach is the ideal answer because the rules could work the same no matter where it sits.
TIP: In the meantime, please know that when you're in the Parts Item Edit or Labor Item Edit window per item, you may apply a different labor rate or parts price level to the respective item(s). Click on the Type button and choose from your existing system rates.
