Dexron VI
Posted: Tue Jul 05, 2011 1:24 pm
Dexron VI is supposed to be the replacement for Dexron III. According to GM, it should be used in all applications and I'm seeing that OD5 data is reflecting that now. My question is what is actually happening out in the field and what are your opinions on the matter? Are you still using Dexron III?
TIA,
Ric
Re: Dexron VI
Posted: Tue Jul 05, 2011 2:05 pm
by nickscarcare
I have been still using dexIII for all the older stuff. When installing new transmission, then it does get dex 6. All newer vehicles get dex 6. Always went by what book called for, except for the exclusions stated.
Re: Dexron VI
Posted: Tue Jul 05, 2011 2:43 pm
For us, any GM now gets Mercon VI. Works well in all applications so far. We like it except for the price.
Re: Dexron VI
Posted: Tue Jul 05, 2011 3:15 pm
by a&mauto
We are using DEX 6 and Wolfshead synthetic in almost everything.
Re: Dexron VI
Posted: Wed Jul 06, 2011 1:25 am
as we all know i'm fluid specific. the dex issue is a simple one. each level of dex will superseded the other with the exception of synthetic. personally, i wouldn't use mercon in a g.m but that's a personal choice. there are shops that claim the cross use can resolve issues. i'm not one of them. there are chemical engineers that are way more qualified than i am and i've seen results of improper fluid usage. there are "universal" fluids out there and i'm sure if i looked in a walmart, autozone, target, etc i'd find a universal transmission fluid. let it stay on the shelf. oh ya, when you're reading the specs on the back make sure they stand for something. if it say's meets or exceeds all usa guidelines it could mean "you stupid a**"
it's like synthetic blends. i've never seen any manufacturer recommend them. will i use them? n.f.w.
Re: Dexron VI
Posted: Thu Jul 07, 2011 5:03 am
by mopwrforme
Re: Dexron VI
Posted: Thu Jul 07, 2011 5:40 am
GM put out a TSB # 04-07-30-037D dated November 21,2007 that says that Dexron VI is to be used in all warranty repairs and is compatible with Dexron III in any proportion. Based on that TSB from GM is why I use Dexron VI in any GM vehicle. I quote from that TSB "Current and prior automatic transmission models that have used Dexron III must now only use Dexron VI." So far, I have not seen any issues, negative ones that is. Actually the comments I have gotten so far is that shifts seem to be firmer and better, one driver even ventured that fuel economy is up since I flushed out the trans and installed Dexron VI. I also questioned a local trans rebuilder in my area and he also uses Dexron VI whenever he rebuilds a GM trans of most any model. I suppose though it is a matter of whatever you as the shop owner want to be comfortable with.
Re: Dexron VI
Posted: Thu Jul 07, 2011 7:01 am
I use valvoline maxlife synthetic in all dex 6 vehicles unless its a really old gm then i use shell multivehicle atf in those.
