1996 Ford Explorer - 5.0L Miss
Re: 1996 Ford Explorer - 5.0L Miss
brianp87 wrote:
civicsi1279 wrote:I NOTICED TODAY WHEN I PULLED # 8 SPARK PLUG WIRE IT WOULD SAY #6 IS MISSING. IF I PULLED # 5 IT WOULD SAY # 7. IM LOOKING AT THE FIRING ORDER DIAGRAM AND ALL THE WIRES ARE IN THE CORRECT SPOTS. EVER HEAR OF THIS ANY SUGGESTIONS.
This would indicate something other then trans? Lets start over what have you checked?
all in all with all the information i would agree. but, it won't act up in regular drive or third. just when it shifts into overdrive and it won't act up when doing a brake stand. i bet the scanner is picking up a misfire code because when it drops into overdrive the timing curve is at the bottom of the curve. `without having the vehicle and watching the data stream it's the beast i can come up with. i'de like to see a bunch of debris in the tranny pan to help me justify it being the problem................
So if Im reading this correctly it only misses at low rpms but not in the bay has to be driving? does it feel like an ignition miss?
wbuxton
1000 Club: Interstellar
Post by wbuxton »
Put a tube of "Dr. Trannys shudder fix" in it. O'reilly sells it for about $8.00
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
civicsi1279
Post by civicsi1279 »
yes only at low rpms but not in the shop or idle. only does it when it seems to shift to the next gear.
Does ur scanner offer the availability to watch the torque convertor lock up if so see if it happens at the same time
liljoe
Post by liljoe »
How bout removing the wire from the connector at the transmission for the converter lock up and see if the problem goes away, if so you can bet it is prob in trans.
civicsi1279
no my scanner doesnt have the torque converter in the scanner
Return to “Ford Trucks”
