History was customer had vehicle at another shop for tires, after mounting the tires, the VSA, Brake and ABS lights came on and would not go off. My suspect was someone had beat the wheels off damaging a Wheel Speed Sensor. No visual damage was found. TPMS is functioning as designed. My lovely Genysis will not read Wheel speed. When I try to communicate with the VSA, at first I get an error saying "the Vehicle could not be identified and has returned diagnostic P/N 2003256546" ( that is not the actual number but its long) So I hit the exit button and then try to go right back into the VSA and it then says " Vehicle Identified" and connects to the VSA, If I try to go any further I just get a message saying the VSA has returned an error code 84-1. I cannot find "84-1" in any manual here or in my OD5. OTC has no clue either, they have even updated my software trying to resolve connection issues with this car( and some Fords)
No OBDII trouble codes are stored.
Any Honda guys out here??? The car is not here at the moment,
I'm just lost on where to start on this one.
I am assuming that when the tires were mounted they were put back into their original positions.. but if they were not, wouldn't that have set the TPMS light on?
try to check back often, bear in mind i'm 4 hours behind you east coast guys.
