2000 Nissan Maxima - Code P1220
lion012368
Post by lion012368 »
hi folks
here is the problem p1220 code on comes on i understand that is for fpcm but i could not locate that fpmc(fuel control module) any help to locating that unit i checked in trunk left,right every where but i could not find
please help me on this
thanks
Re: 2000 nissan maxima code p1220
remove glove box and there she be.
My data states it's in the trunk, LH side. Probably behind the trim. I can send you pics if you want.
Again i stand corrected. I looked up pcm, not fpcm. on second look it appears to be where Ric said it was. It's on the side with the gas door. At least by the picture i looked at and it appears to look like a big relay. It has two mounting studs, rectangular, and the harness plugs into it. By the picture there appears to me two relays towards the front of the inner fender, the one on the inside is the one you're looking for. I looked it up under a GLE. If you can't get through to Ric call me and i'll fax a picture. I'll be out between 8 and 9am.
Return to “Nissan / Infiniti”
