Well, I'll need to find the time, or should I say make the time for that to happen. But, I do thank you for your input.
Update 8.5.02
Re: Update 8.5.02
- Site Admin
Re: Update 8.5.02
ShopManTim, I looked further into it and it looks like you may be experiencing our issue where the wrong columns are displayed in the New order screen. We're working on correcting this behavior.ShopManTim wrote: ↑Fri Apr 14, 2023 5:01 amWell, I'll need to find the time, or should I say make the time for that to happen. But, I do thank you for your input.
To fix it you simply need to toggle the "Display for" to Customer then back to Company. If the issue recurs just repeat this fix, toggling between Customer and Company.
-Adam
M1 Support
Re: Update 8.5.02
Ok, so I tried this and it works. If i can get it that close, I am ok with it but it had not been that way with the prior update.LeapingGecko wrote: ↑Fri Apr 14, 2023 10:15 amShopManTim, I looked further into it and it looks like you may be experiencing our issue where the wrong columns are displayed in the New order screen. We're working on correcting this behavior.ShopManTim wrote: ↑Fri Apr 14, 2023 5:01 amWell, I'll need to find the time, or should I say make the time for that to happen. But, I do thank you for your input.
-Adam
Re: Update 8.5.02
Ok, so after a number of weeks of functioning well, this morning I opened my work station only to see that, once again, the columns are all back and totally scattered. I am very disgusted to say the least. At my age and with the duties I have here, I do not need this kind of frustration in my schedule.
So I will reorganize the columns, once again, and see how long it goes till it happens again.
Re: Update 8.5.02
Similar experience here. Installed the update quite awhile ago, never had a column issue. Just this week we had two different occurrences of the columns rearranging. Can't pinpoint what actions/steps were taken on our end to cause the column shift so we are unable to re-create the problem. It's DEFINITELY annoying!ShopManTim wrote: ↑Fri May 12, 2023 2:28 amOk, so after a number of weeks of functioning well, this morning I opened my work station only to see that, once again, the columns are all back and totally scattered. I am very disgusted to say the least. At my age and with the duties I have here, I do not need this kind of frustration in my schedule.
Re: Update 8.5.02
2 computers both logged in with different usernames after going since my last post today the one on the server just rearranged everything including putting hidden columns back. I know you already know about this issue and this doesn't help other than it helps me get some frustration out.
Re: Update 8.5.02
Ya know, I am wondering if the powers that be are not trying to ask the system to be able to do too much. And, we as older technicians fail to appreciate the technology like the younger ones do. I am at the point where it would be just as easy for me to revert back to the way I did things 30 years ago when everything was hand written and a physical hard copy of everything was always available the way I wanted it. I am far from being convinced that with all the technology around us that we are better off. Too many problems with it to say nothing of the mental frustration and delay in being efficient.
Just saying.
Having vented some of my feelings, I do want to thank Mitchell 1 for what it has put together. Many thanks!
Just saying.
Re: Update 8.5.02
HELP. MY SCREEN IS STILL NOT RIGHT. THANKS
Re: Update 8.5.02
This is an old thread; please confirm the version of Manager SE you're running.
The newest release is 8.5.2.670; it's available from Help > Check for Updates if you don't have that yet.
