Estimate Still Visible After Convert To RO?
AndyHull
Post by AndyHull »
A recent RO was different than the Estimate after converting. Is there a way to see the original estimate after converting to an RO?
Andy
Re: Estimate Still Visible After Convert To RO?
Andy, Welcome to the Forums.
As far as i know there is no way to see the estimate once turned to an RO. However, there may be other ways to see what you need to find out. Shortly the other will have shaken the cob webs and will be here to help!
Welcome To The Forum and thanks for your question.
The short answer is no.
When you say different, I'm assuming this refers to the running totals no longer matching? The numbers match up until an RO is marked as printed. Any changes after that point and the numbers will start to differ.
Please confirm what the question to be answered is.
Jeff @ Able Auto
Post by Jeff @ Able Auto »
I check the totals from the revision page before I sell it. In revisions click "sell revision". Then be sure to have all the revisions you are selling checked/marked. At the bottom you will see a total including the amount on the current RO. I just caught onto this feature a year or so ago. :oops: It saves a lot of math and scratch paper!
That's true. Coupled with that, Options - Revision History stores the transfer approval info in case that is ever needed.
If this shop used Revisions, you have provided the answer. I didn't see that as yet.
Jeff @ Able Auto
OOOPPPSS...I guess I didn't read it closely enough.
