Can a part be removed fron inventory without being on an invoice?
dtsservice
Post by dtsservice »
I have a question for the TeamWorks SE users out there. We are having issues keeping up with our oil inventory because of the way we bill out Service/Lubes.
We take the price of the oil used, add our labour and bill that total out as a labour line. We do it this way because of the wide variety of vehicles/machinery we work on. Helps keep everything tidy and streamlined on the printed invoice.
I am wondering if there is a way to have the oil removed from inventory without seeing it billed on the invoice? We can physically go into the inventory and remove that amount, but if there is a different way of doing this we are open to it.
Thanks
Re: Can a part be removed fron inventory without being on an invoice?
Have you looked into Packages? These allow for a single price externally but you can add parts inside the package. They show as one line item on the order and inventory will deduct.
dtsservice
No I haven't. Is this the same as a part kit?
ShopManTim
Post by ShopManTim »
You got my curiosity. At the risk of being overly negative and/or critical, what is the reason you do not want to show the oil used on an invoice?
dtsservice
ShopManTim wrote:
Tue Mar 26, 2024 12:33 pm
We print it in the labour line, it would look as such:
15W - 40 x 32L
PERFORMED SERVICE LUBE
CHECKED ALL FLUIDS
LUBED ALL HINGES/LATCHES
GREASED
If that makes sense. So on an Invoice with multiple repairs, the customer knows exactly what they are paying for the service/lube alone.
I don't think you'll have to worry about this too much longer. We're working towards a solution that will allow you to use the program correctly and meet that customer need.
dtsservice
Silky7 wrote:
Tue Mar 26, 2024 2:20 pm
What exactly does this entail?
Line items will be grouped into jobs, and jobs will be clearly presented with their own subtotal. So when a customer of your shop has additional work, they'll still clearly see the charges for the LOF.
