PO Editing
PO Editing
Since the 8.5.1.419 update when I go into a po and click on a part number on the po, when it opens it changes the quantity to order back to one. If you click cancel it goes back to the quantity you had to order, if you click ok, it goes back to one. Anyone else come across this?
- Site Admin
Re: PO Editting
This is something that we've noticed for inventory items on purchase orders. The quantity to order defaults to 1 instead of the current value. Development is aware and it will be resolved in a future update.
In the meantime make sure that you double check the quantity when you edit parts in purchase orders.
M1 Support
Re: PO Editting
Thanks!LeapingGecko wrote: ↑Fri Mar 31, 2023 5:37 amThis is something that we've noticed for inventory items on purchase orders. The quantity to order defaults to 1 instead of the current value. Development is aware and it will be resolved in a future update.
Re: PO Editting
When you go to receive a po and open a part that has backorder quantities on it, those have changed to zero. Hopefully this gets resolved soon.
Re: PO Editting
Anyword on this update to fix this coming out soon?
- megoff
Re: PO Editting
At the current time there is no ETA on the release with this fix. I can get you added to the list of beta customers for when the next release is available if you'd like.
Re: PO Editting
It was indeed a pretty quick fix. The update distribution is not. It still takes an entire update, so this is being rolled up with a number of other items (including the WIP grid fix for resetting).Springguy368 wrote: ↑Mon May 01, 2023 4:24 amShouldn't this be a quick fix since it wasn't a issue til the last update?
Re: PO Editting
Thanks!Silky7 wrote: ↑Mon May 01, 2023 8:38 amIt was indeed a pretty quick fix. The update distribution is not. It still takes an entire update, so this is being rolled up with a number of other items (including the WIP grid fix for resetting).Springguy368 wrote: ↑Mon May 01, 2023 4:24 amShouldn't this be a quick fix since it wasn't a issue til the last update?
