First let me say that I did submit this via feedback but I had to amend it due to character limitations.
Subject vehicle is a 2005 Toyota Tundra 4.7 SR5. CEL is on with codes P1441, P1444 and P2440. These codes are for the secondary air injection system. Most of the components are under the intake, as is the starter on this model. I used the search function for P1441 and found my diagnostic routine; there even was a routine for these specific 3 codes together. As I suspected, I had to pull the intake to do some of the testing. The TSB button was NOT lit. The testing showed the Driver module to be bad, which is one of the only items not located under the manifold.
Later I was doing some personal training on the system and decided to know a little more about the driver. I searched again and got Air Injection System. I clicked on that and discovered a TSB that had a whole new diagnostic routine. So why did this TSB not come up when I was in the individual code? None of these individual codes causes the TSB to be known or shown. Isn't that the way the TSB button works for relevant codes?
Missing TSB Link?
Missing TSB Link?
Re: Missing TSB Link?
I have sent this one on for followup - stay tuned
"We did some research, based on the information in the string from Tim’s Forum, I believe the user is referring to Toyota TSB AIR INJECTION SYSTEM MIL ”ON”, # T-SB-0230-12 Rev1, issued on October 17, 2013.
Current TSB search results in ProDemand will provide a return when the searched term appears in the title, not the body of the article. In this case the user was looking for a DTC not in the title, the result was, the user is not directed to this TSB. This is not uncommon, I see TSBs that list symptom/components/conditions in titles that do not include DTCs."
It appears that would require some modification of the TSB Search scope to catch instances like this.
Well that would explain why the TSB did not come up. I was not aware that the exact code needed to be in the title, as probably other users. I rely on the TSB button when doing code diagnosis to pop up for me.
It's good this was brought to light. Users should use the linked TSB's when lit but should ALSO search the entire TSB's database, narrowing by category, before moving ahead.
Thank you.
Thank you.
