2003 Chev Cavalier 2.2L PCV?
dunlapautomotive
Post by dunlapautomotive »
Cannot find info on where PCV is located on engine. I have a 2.2 using oil and is going into air cleaner tube through crankcase vent hose. It looks to me like I have no vacuum through PCV valve. Any help would be great, Thanks
Re: 03 Cavalier 2.2 PCV
I can't find one. I have an ex-gm dealer tech and he thinks it might be built into the valve cover. Sorry I couldn't be more helpful.
Looked up part by application and there isn't one. Just a quickie here, is there any crapolla on the inside of the oil cap or tube? I've seen these engines sludge up a lot. With oil cap off and engine running is there a slight vac pull? As a rule i place may hand over the oil fill port and see if there is a slight suction on my hand. If there is then the engine is breathing properly, if my hand feels like it's being pushed away then there is a breathing issue or a ring issue.
1000 Club: Interstellar
Post by Pauls Automotive »
On old trick to feeling this very slight vaccum was to put a 8x11 inch piece of paper over the oil cap hole and if it sucks it down then your pcv is working well. if it blows it away look for problem. I have never seen a pcv valve with this engine. I believe it is all part of the valve cover assembly as stated earlier.
brother bubba
Post by brother bubba »
Go to figure 338 of engine mechanical. It shows cleaning the crankcase ventilation passages in the intake manifold. I'm thinking it must be a metered air bleed built into the manifold.
Return to “Model Coverage”
