Order Hrs vs Actual Hrs
Mobile Manager Pro (tablets)
Gerald Martin
Post by Gerald Martin »
Is there a quick way to visualize the tech's efficiency on a per-work-order basis? For instance, the order screen displays total labor hrs. Where can we see a total of actual hrs (if the techs are clocking in and out on labor items using Mobile Manager?)
Maybe the answer is hiding in plain sight.
Gerald
Gerald Martin
Re: Order Hrs vs Actual Hrs
Anyone?
1000 Club: Interstellar
Post by Pauls Automotive »
I don't know of any quick way within Mitchell short of manually making the calculations. I ended up using a third party program that is a time clock that the guys sign in for the day but also per job that integrates with Mitchell and gives me all those numbers. It is called Labor Profit Management.. If that is of any help.
Gerald Martin wrote:Is there a quick way to visualize the tech's efficiency on a per-work-order basis? For instance, the order screen displays total labor hrs. Where can we see a total of actual hrs (if the techs are clocking in and out on labor items using Mobile Manager?)
Gerald
That data is not being written back to storage in SE; if any reporting was to be available it would be in their ReportPro portfolio.
Since MM Pro / time clock is referenced, I am moving this to their topic area.
Auto Repair Coach
Post by Auto Repair Coach »
Currently, without using the Labor Profit Management Software mentioned above, there is no way in Mobile Manager to automatically calculate tech efficiencies. No data is written since there is no place to put it at this time. No data, no reports. (Example. Where would tech punch in and out for the day go?)
John Burkhauser
BOLT ON TECHNOLOGY
Return to “Mobile Manager”
