Fluid Capacities On Tech Worksheets?
I have noticed that the capacities do not print on tech worksheets. Can this be fixed? Thanks, Jeff.
- Johnny5
Re: Fluid Capacities On Tech Worksheets?
What version of manager and which tech worksheet are you using?
Version 6.5.42...Pro Pack std tech work sheet.
I just use the fluids button and ad it to tech sheet
There is a line for fluid capacity, it just doesn't show the capacity.
OK...i am still not getting fluid caps on pro-pack tech sheets!! Any ideas? Shows the line..no capacities!
OK..so I am going blind. I was looking at the end of the string and it was on the front. Monday Monday!!
Whew!
It's Monday everywhere.....
Thanks for understanding. I sometimes blame it on the 70's!
OK...updated to 6.5.47 and lost the capacities again. And I looked very closely this time
. Line is on tech sheet but no cap anywhere. 6.5.47 with pro pack tech sheet.
I just found a clue. The ticket in question spaced the fluid cap to a second line. When I back spaced it to the first line it printed.
Example
Oil capacity
5 quarts 5w30...only prints oil capacity line..no 5 quarts 5w30
oil capacity 5 quarts 5w30...prints complete
Does this make sense? Thanks Jeff.
Example
Oil capacity
- MRISICH
Hi Jeff,
Can you connect to a remote support session so we can take a look at what's going on and try to fix it? Here's the link: http://www.boltontechnology.com/support.html.
Thanks,
Mike
Thanks,
Mike
