2004 Ford Taurus - 3.0L DOHC Multiple Coil Codes Fixed!
Posted: Thu Sep 23, 2010 10:45 am
Hey, first time poster here. have a 2004 taurus in my shop. Vehicle came in running rough.
Tune up parts were worn out so we tuned it up, factory plugs and boots, has c.o.p ignition system. Mil was on also with po351, po352, po354 coil codes. After tune it still has a skip. Did a power balance test and the only cylinder not working is #4. Also still has repeating codes, po351, po352, po354. Checked spark at all the coils and they all have great spark. Just for the heck of it I swapped coil #4 for coil #3. The skip in #4 is still there, and same codes. Swapped #4 injector with #3, skip still #4. put new coil on #4 even thogh it had good spark, skip still #4, still same codes.
Wiggled and jiggled and pulled every wire and wire harness,and did continuity tests on every related wire and connection. Did a compression test, all cylinders right at 200 psi. smoke tested eng for vac leaks, has no leaks. Watched the injectors spray fuel, all good. Fuel pressure is good 48 p.s.i. Customer also stated that ac not working. Diagnosed that as a bad pcm, was not triggering ac relay. Sent the pcm off to be rmfg. The hope was that the skip may also be pcm related. Pcm came back a few days later but neither issue was resolved.
Spent several hours after that re-checking everything ac related and determined pcm not fixed correctly and are sending it back for further repair. I am not hopeful at this point about the pcm fixing the skip. If anyone has any thoughts or ideas about the skip, please help.
Thanks Bob in Greenville SC
