Page 1 of 2
1997 Mazda Protege - Transmission Code
Posted: Mon Aug 03, 2009 5:05 am
by civicsi1279
i have a 97 mazda protege w/ 1.5 auto. the overdrive like will start blinking every once in a while and put the car in overdrive. i have scanned the computer and i will get a speed sensor code. could a speed sensor cause this or is the tranny on its way out?
Re: 1997 mazda protege with transmission problem
Posted: Mon Aug 03, 2009 5:35 am
by wbuxton
A blinking light typically is the computers way of telling you there is a problem, such as the MIL. Are you saying the light starts to blink and the transmission goes into high gear?
Speed sensor will usually cause them to fall out of overdrive.
Posted: Mon Aug 03, 2009 6:12 am
What code are you getting?
Posted: Mon Aug 03, 2009 8:13 am
by civicsi1279
i am getting a 715 turbine speed sensor.. when the light starts the blink the car shifts into over drive and rpms go up
Re: 1997 Mazda Protege - Transmission Code
Posted: Mon Aug 03, 2009 8:34 am
Check the resistance of the sensor. If its is ok then test the wiring to the ecm.
Posted: Mon Aug 03, 2009 9:01 am
by civicsi1279
all that checks out to be normal. could a speed sensor cause this
Posted: Mon Aug 03, 2009 9:04 am
Heat up the sensor and see. is the computerunder the center consule? check it for water damage like a drink
Posted: Mon Aug 03, 2009 9:20 am
sounds that since it's ccasional, it's a bad connection.
Posted: Mon Aug 03, 2009 10:30 am
If the sensor, wiring, to sensor and ecm are all good then it has to be an internal problem
Posted: Mon Aug 03, 2009 10:38 am
I would recommend you scope the output of the sensor and compare it to a known good signal.
Posted: Mon Aug 03, 2009 11:36 am
I bet its the sensor but he says it is ok
Posted: Wed Aug 05, 2009 6:40 am
Any news?
Posted: Mon Aug 10, 2009 3:41 pm
by civicsi1279
i put a new sensor in and still the same thing
Posted: Tue Aug 11, 2009 2:55 am
even the dealer said there are wiring issues with these beauties. the leads have a habit of backing out of multi-plug.
Posted: Tue Aug 11, 2009 6:15 am
So we have good sensor, good wiring, ecm or internal trans
Posted: Tue Aug 11, 2009 11:30 am
by civicsi1279
i'm thinking its an internal issue with the trans
by civicsi1279
Posted: Wed Aug 12, 2009 2:28 am
there are solonoids in the tranny that can cause these issues. too much line pressure can cause this.
Posted: Wed Aug 12, 2009 6:35 am
Does it give a way to check pressures
Posted: Wed Aug 12, 2009 6:57 am
by civicsi1279
what do u mean
