2012 Prius
2012 Prius
Vin # JTDKN3DU6C1589174 it decodes but says no labor info available?
Re: 2012 Prius
I'm getting parts & labor content when I click on the Estimator button. When I clicked on Repair Information I did get a sub-model question to resolve: [despite Prius Two being visible in SE]
2012 Prius.png (9.86 KiB) Viewed 9448 times
I'll be sharing this with the appropriate department.
Re: 2012 Prius
Mine will not show anything from the estimating button.
mitch error.JPG (28.69 KiB) Viewed 9424 times
Re: 2012 Prius
What version of SE are you running?
Re: 2012 Prius
Re: 2012 Prius
If you can manage it sometime soon, I'd go to m1files.com and use the SE 6.6.10 download link and get updated.
Re: 2012 Prius
Ill try it. Does it not auto update any longer?
Re: 2012 Prius
It does. But the roll out has not got you up to the latest update. We have went to 6.6.8 manually also. Not had time to go to 6.6.10
Re: 2012 Prius
brianp87 wrote:Ill try it. Does it not auto update any longer?
Yes of course it does; not everyone at once and I don't know when you'll receive it otherwise. This is a manual option provided to remedy shops requiring a fix that's on the latest release without delay.
Re: 2012 Prius
timbre4 wrote:If you can manage it sometime soon, I'd go to m1files.com and use the SE 6.6.10 download link and get updated.
I cannot find the link any were.
Re: 2012 Prius
Its right toward the top. Don't look in the list were you would think it is.
I looked all over heck for it also
Re: 2012 Prius
Nope, it changed. I will find it.
Re: 2012 Prius
Re: 2012 Prius
Tims "link" didn't take me there.
Jeff @ Able Auto
Re: 2012 Prius
Post by Jeff @ Able Auto »
Unless it falls off the link after you update it is no longer there. It was there because I updated when it was released.
Re: 2012 Prius
Mine does not look like that?
mitch error.JPG (71.75 KiB) Viewed 9379 times
Re: 2012 Prius
Brian - it still lands on Manager 5.9 page (due for overhaul soon); you need to go one page further. Click on B Manager SE v6.x Support Files >>>> SE v.6.5, 6.6x SUPPORT
Re: 2012 Prius
timbre4 wrote:Brian - it still lands on Manager 5.9 page (due for overhaul soon); you need to go one page further. Click on B Manager SE v6.x Support Files >>>> SE v.6.5, 6.6x SUPPORT
That worked. Thank you
Re: 2012 Prius
Good to know! I was lost. I know i had seen it in another link.
Re: 2012 Prius
Im gonna have to call support updated the host first then the work stations and they do not
Return to “VIN Decode”
