Vendor Name Change?
sbcauto
Vendor Name Change?
Post by sbcauto »
I Have A Vender Whose Name Has Changed. All Other Info Stays The Same. I Am Unable To Edit & Change Name & Code. Do I Have To Delete This Vendor And Start All Over??
Thank
KGA
Re: Vendor Name Change?
Post by KGA »
Should be able to go to you Vendor listing click on the vendors name that you would like to change and click on edit. I've recently done this with a couple of our vendors.
sbcauto
Post by sbcauto »
OK That Worked Changing Name. I Was Trying To Change Code First. Will Not Let Me Change Code? THANKS
Please note that the Vendor Code is used internally in several places behind the scenes and was probably in play somewhere; that is likely why you were not allowed to change it.
boniauto
Post by boniauto »
they should also have search field for vendors
boniauto wrote:they should also have search field for vendors
There is..... just right click on the Vendor heading.
Click on any column name to SORT A>Z or Z>A; right-click any column name to SEARCH:
