Grid Background Color Resets On Exit?
Qbasic8
Post by Qbasic8 »
I'm using Manager 6.6.9. On startup from a workstation the grid line colors will automatically be reset. "Grid Background = White". I will switch it to yellow and it will switch and work for the duration Manager remains open. If I restart manager it will be white again.
Re: Grid Background Color Resets On Exit?
Are your other screen preferences being remembered? (User profiles, printers, etc)
Qbasic8
Post by Qbasic8 »
The printer is remembered (but their is only one printer at our location). Changing the WIP Column Headers order (Drag and dropping Customer to another location) will not be remembered upon restart.
Do you have User profiles or does it still say Default User in the lower RH corner? I believe we made the Default User hold some settings recently and I want to be able to point to that or rule it out.
Qbasic8
Post by Qbasic8 »
Default User on the lower right of the status bar
EDIT: That statement may be incorrect; the PC I use for the videos was set to Default User when the power went off last night so it may not have been able to write those settings.
Watch this video and see how to create at least one User profile and then select it to be listed down in the lower RH corner.
Create a User (Profile): https://youtu.be/XvMdMLK_pmU
Qbasic8
Post by Qbasic8 »
Ok, after setting the machine to use another "User Selection" it loads correctly after a restart. Thanks for pointing me in the right direction!
Whew, anytime.
