Fax/Printer Selection Issue FIXED [WIN 10]
nickscarcare
Post by nickscarcare »
Not sure if anyone else has had this issue. If I fax a copy of the invoice to a customer, then go to charge it out, the printer stays on fax, I have to go to the drop down and choose the printer option and set it back to the printer and not fax. I am running 7.0.11 and it seems to happened since the last update?
Re: Fax/Printer Selection Issue FIXED [WIN 10]
Take a look at this article. If you're on Windows 10, it's most likely the reason you're seeing this behavior. http://winaero.com/blog/how-to-stop-win ... t-printer/
nickscarcare
By the way yes that was it. Thank you.
