Invoice Printing
Invoice Printing
Is there a way to add spacing between printed Labor lines on invoices?
Re: Invoice Printing
There is not, I did however add a bit more space between lines in the last update to that template. That version will appear in v 7.1.7
Johnny5 wrote:There is not, I did however add a bit more space between lines in the last update to that template. That version will appear in v 7.1.7
We're on 7.1.7. Is there any work-around's that we may be able to take advantage of? Adding spaces or a newline character in the Work Request/Work Performed fields?
Sorry - meant to type version 7.2 .... The only way to change spacing is to open and modify the report using crystal reports developer tools.
Johnny5 wrote:Sorry - meant to type version 7.2 .... The only way to change spacing is to open and modify the report using crystal reports developer tools.
Interesting, I used to, among other things, do Crystal Reports development & Dashboarding while I worked at SAP America. Not to be a pain but any ETA the 7.2 release or early adopter for 7.2?
PMFJI - Mid-late April for SE 7.2
Is there any update on this one? We're on 7.2.9 and just printed a big job and the invoice is still very difficult to read, the labor side of the invoice looks like one huge paragraph.
Which template are you using?
We are using INV Stk Paper w/o Hours. Is there a better one with a similar layout that we should be using?
Any update on this one?
GUTHTIRE wrote:Any update on this one?
BUMP
andysautorepair
Post by andysautorepair »
BUMP. Have Ver 7.3.11 very difficult to distinguish between lines in labor column. Should have option to have 1.5 or double spacing.
Hello and Welcome to the Forum!
I want to make sure we can record this request accurately. Am I correct in assuming you mean the vertical space between lines of the Work Performed, like so? (1.5 spacing, Work Requested description bolded for reference point)
Silky7 wrote:Hello and Welcome to the Forum!
The attachment spacing.png is no longer available
The horizontal spacing. Everything seems to run together.
Any update on this one? I was hoping this would be a quick adjustment and not have to wait for a new version of ShopKey.
GUTHTIRE wrote:Any update on this one? I was hoping this would be a quick adjustment and not have to wait for a new version of ShopKey.
We're been preparing for the AAPEX show for weeks; this is wrapping up tomorrow. When the smoke clears let's confirm what your expectation is when we're back in the office next week.
Sounds good!
BUMP
