Driver Contact Name Not Printed On RO?
A few releases ago there wasn't field for a customer's first name to be associated with the phone number list. Back then we were using the extension field to specify the first name, albeit it was truncated. Since then there's been an addition space provided for a name which is great however the RO now shows just the phone number. This creates a bit of a issue when contacting the customer in that by looking at the printed RO you have no idea whose phone number it is that you are calling. The only way to tell is to go to Customer Screen for that vehicle.
Can we get the "checked" names and numbers from the Telephone List printed on the RO and for that matter the printed Invoice as well?
Re: Driver Contact Name Not Printed On RO?
Hi
In the next version to be release very soon, driver information and driver phone is printed on repair orders and invoices. The next version I am asking for the base telephone number notes to be printed.
Johnny5 wrote:Hi
Great, thx!
It will look something like below, if there are notes with the selected phone numbers, two lines will be used.
Johnny5 wrote:It will look something like below, if there are notes with the selected phone numbers, two lines will be used.
Thanks for the pic. From our standpoint just the name would suffice. But it would, if possible and eventually, coincide with the checked number or numbers in the Telephone List.
Example: If Steve and home were checked ###-###-#### Steve, ###-###-#### Home (If only Steve was checked maybe Home would be a default. If Steve and Valarie were checked ###-###-#### Steve, ###-###-#### Valarie.
It does this now: Coincide with the checked number or numbers in the Telephone List.
Johnny5 wrote:It does this now: Coincide with the checked number or numbers in the Telephone List.
The only way that I see to get a name to show on an RO is to put the name in the Ext. field. If I use omit the name in the Ext. field it just shows the number. If I add a driver and phone number it still just prints the number. The report that we're using for RO's is "RO with Part Detail". FWIW, the only time we assign a "Driver" is with Companies that have multiple vehicles.
DynaBMan
Post by DynaBMan »
I see this as a feature that I am definitely going to utilize in our shop. Any idea when the release is going to start rolling out?
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
Trying to wrap this new version this week, it will go to tech support next week for their review, then shortly after we will start deploying to users.
DynaBMan
Post by DynaBMan »
Johnny5 wrote:Trying to wrap this new version this week, it will go to tech support next week for their review, then shortly after we will start deploying to users.
I am really looking forward to the new version. Any more news as to when it could be deploying to users? Or is there a way to manually download it?
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
It is available now, you can download the update from http://www.m1faqs.com/fix/SE , I strongly suggest you not do this update in the morning or the middle of the day. Do it at the end of the day, if you get stuck ring up tech support as soon as you can.
DynaBMan
Post by DynaBMan »
Is there a good likelihood that the install will give me troubles? :D
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
The main issue we see here with installation is 1. User needs to temporarily turn off Windows firewall, 2. must be logged into pc as Admin, and 3. Exit all other running programs and temporarily shut down anti-virus software for the update install.
DynaBMan
Post by DynaBMan »
Installed and up and running like a charm. So far, I like a lot. :D :D :D :D :D
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
Is this change integrated in version 7.3.7 or do you still have to run the fix?
On our RO's under "Technician Work Sheet" is says:
CUSTOMERLASNAME, CUSTOMERFIRSTNAME
Cellular 123-456-7890 --- Cellular 2 123-456-7890
On our Invoices under the customer address:
Shouldn't both be:
Cellular 123-456-7890 CUSTOMERNAMEFROMNOTES/NAMEfield --- Cellular 2 123-456-7890 CUSTOMERNAMEFROMNOTE/NAMEfield
We are using the following templates:
for Repair Orders: RO with Part Detail
for Invoices: INV Stk Paper w/o hours
for Tech. Worksheets: Expanded Worksheet w. Charged Hours
