Points Editor - Imported Points
When I first got ProPack, I downloaded some inspections from the Store to see what people were doing. Since then, I've created my own inspections. Along the way I've likely used some of the inspection points from imported inspections in my own inspections. Now my inspection list is getting cluttered and I want to remove these non-Motorcar inspections. If I do, will I lose those imported inspection points in the editor that are used on my own inspections?
- Auto Repair Coach
Re: Points Editor - Imported Points
Ric,
If you attempt delete any point from the menu and it is in an inspection, you will informed that it must be removed from all inspections before it is deleted.
If you are deleting a complete Non Motor Car inspection, the inspection points do not go away. When deleting an inspection you may see the list of points on the left shift as the points are moved from the inspection to that window.
Hope this helps.
Hope this helps.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
Thank you JB. I deleted the old inspections and all my points were intact. Great work, guys!
- Auto Repair Coach
Woo Hoo!
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
