README for ManagerSE_Update_8.2.1.81
Perhaps I missed it, don't know where to look, or using an invalid keyword search but is there a README for ManagerSE_Update_8.2.1.81?
Re: README for ManagerSE_Update_8.2.1.81
Manager SE Changes
v 8.2.1.81
Fixes from 8.2.1.79
Issue transferring parts from some catalogs resolved
v 8.2.1.81
Fixes from 8.2.1.79
Dan,
Release notes are always viewable for any release by clicking on the "What's new in this release" button on the home splash screen. Ric gave you the incremental changes from 8.2.1.79 (because he was in the beta for 8.2.1.79), but those are applicable to this version as well.
Correct however, it would be beneficial to see Release Notes posted somewhere prior to installing. This provides us with insight as to what changes are in the release prior to the upgrade and enables us to make a more intelligent decision as to upgrading now or wait on a follow-on release.Silky7 wrote: ↑Thu Oct 15, 2020 11:47 amDan,
v 8.2.1.81
Fixes from 8.2.1.79
v 8.2.1.79
New setting (Default Setting tab) to always prompt when emailing and customer has multiple email addresses
MPI Sharing template changed to require more than just a MPI URL - reduce likelihood of carrier flagging message as SPAM
Text Message center updated to include support for Canadian phone numbers
New setting to customize and automatically change Order status or Appointment status when the other changes. Setup->Standard Descriptions->Status->Status Map
Email field on customer screen can be directly edited when first setting up a customer. Afterwards, must utilize the email editor dialog to add/remove additional email addresses
Report Changes
Can now assign report password (in Report/Printer Setup) to control access to online reports
New MPI usage report: Reports->Management->Multi-Point Inspection Usage. Shows number of MPI reports done, passed/failed items, as well as order totals tied to MPIs.
Category Profit report now shows negative part / labor amounts
Mail Merge report now includes VIN
Balance Due Statement DblVu #9 updated to show correct page count
Michigan Invoice Report updated to meet state requirements
Configurable Database Validations (Configuration->Special Maintenance->Database backups and validations) - checks and warns for problems in database that can lead to data corruption. Issues encountered will require technical support.
Fixes
Removed extraneous Backups during application updates causing large backup file
Settings sometimes not saving during program usage. Settings will be correctly saved now - should make all main Setup Settings changes while on the main background screen. Settings will refresh when you open a Repair Order
Scheduler refreshing and appointment loading speed improved
Canned Jobs search no longer crashes when encountering invalid description value
Fix various issues related to saving dates when Windows system locale set to other than US format
Fixed crash when going to electronics parts ordering and a previously selected vendor no longer exists
When decoding a VIN, any values entered in Unit#, Color, and Memo remain - no longer clear
Prevent large database backup size caused by updating DMV data
• 8.2.0.153
Fixes
Resolved Problem running Browser (Intents) on 64 bit OS when updating from older version
Sell Revision option to clear sub-estimates not saving the check state
Scheduler tab not correctly saving the all-day flag when dragging and dropping appointments
Restored behavior allowing an email address to be added directly to email field without having to use the Email List button
v 8.2.0.141
Michigan Report Updated
Added Company Authorized Representative box and signature line
Added underlines for estimated total increase and Authorized by signature
Approved legally compliant for 2020 by Michigan Department of State
Fixes
Fixed issue where application would hang/crash sporadically during certain Windows events
In the Customer tab, allow coping of the read-only email field, even when order is locked by another user
Fixed Page break issue with MPI Report introduced in 8.2.0.134
Fixed wrapping with long text used in the MPI EditBox inspection type - now wraps to multiple lines without overlapping
Fixes from 8.2.1.79
v 8.2.1.79
Report Changes
Fixes
• 8.2.0.153
Fixes
v 8.2.0.141
Fixes
FYI - I do try to post these in SE News; this was about 5 weeks ago: https://managerforum.buymitchell1.net/v ... 54&t=13971
