Wiring Diagram Category update
himels
Post by himels »
For the first time, I was tasked with researching the circuitry related to Blind Spot Monitoring and Land Departure Warning. The vehicle was a 2017 Hyundai Elantra 2.0 Limited. It took me much longer than it should have to locate the wiring diagrams hidden in the Navigation section of System Wiring Diagrams. The repair section only referred me to the "appropriate SYSTEM WIRING DIAGRAMS article".
Is it possible to get either a new category or an addition to the Navigation title to include these new categories so that they are no longer hidden? Thanks
Re: Wiring Diagram Category update
Thanks for your post, I've forwarded this internally for reply.
Any time I need wiring diagrams for ADAS systems, I click on the ADAS button on the home page, then the appropriate system, then wiring diagrams. Gets you there real quick. :D
Bingo. I just got the reply from Repair team to this effect. It sounded to them like you went thru Service Manual to access it rather than the Quick Link shortcut.
ADAS Wiring.jpg (17.92 KiB) Viewed 5264 times
Return to “Using ProDemand”
