2003 Dodge Sprinter 2500 - P2506 Code
GEEPINCJ7
Post by GEEPINCJ7 »
I have an 03 Dodge sprinter 2500 van with a code of p2506 ecm power input. There is no explantion of this code in the Mitchell program. This van comes from the car lot we are attached to. Normally I would not take something like this in because we just do not have the equipment for this van. The van runs and starts normally but has the light on. Any help with this code would be appreciated.
Re: Dodge sprinter 2500 p2506 code
I looked around, I see the code, but my link comes up a dead end. I'll keep lookin' around.
Re: 2003 Dodge Sprinter 2500 - P2506 Code
talk about limbo here. this may be in limp.
NPASC_mike
Post by NPASC_mike »
Check Battery condition/ connections. I think this is just a low voltage code ( dead/ low battery etc.) Like you would expect if someone drove it with bad alternator.
Could this be P2306? What kind of scanner are you using? Can you scan it with something else to verify?
I had a sprinter in last week with a P2457 that i couldnt find info on. I did find a recall that possibly was related but nothing in mitchell.
are you using "global" ?
yes
i'm not seeing it at all. even in manufacturer
Ya me either. I found a recall on identifix recall 44. I only found it under tsb's not recalls. Im not sure it is the fix but it hasnt been done. I couldnt find it in mitchell.
crmeyers
Post by crmeyers »
I believe that error code merely indicates that power to the ECM was too low. Was the battery dead, or had it been dead? Like Mike was getting at above, try a full charging system/battery test and see if you come up with anything. By the way, will the code clear?
Chris Meyers
Service Center Manager
Ocean Air Auto Repair
www.oceanairauto.com
