2002 Lexus RX300 - Yaw Rate Sensor
Princeton Auto
Post by Princeton Auto »
Anyone know where the Yaw rate sensor is on an '02 RX 300? Mitchell says it is at the left rear--SURE!!!
Michael
Princeton Auto Service Center
liljoe
Re: Yaw Rate Sensor on '02 RX300
Post by liljoe »
This is the best I could find, I have never looked for one yet. Hope this helps...
Yaw not Yall.jpg (29.4 KiB) Viewed 11973 times
liljoe
Post by liljoe »
Found this too.....
more yaw.jpg (133.57 KiB) Viewed 11969 times
liljoe
Post by liljoe »
Here is what it should look like....
even more yaw.jpg (139.73 KiB) Viewed 11966 times
Re: 2002 Lexus RX300 - Yaw Rate Sensor
I have the same pic as shown above. I've usually found these under the center console between the seats bolted to the floor. Has to be on centerline with the vehicle. The pic shows it more aft, but usually it's equidistant from the all the wheels.
Princeton Auto
Thanks guys. Looking this morning under the rear seat. I'll find it. Just needed some indications.
Thanks again.
Michael
a&mauto
Post by a&mauto »
Michael,
We have seen some different issues with these on Lexus. Most of the time, we recalibrate them, and the code goes away. These technically should be re-calibrated after an alignment. Let me know if this helps.
Adam Jadovitz
A & M Automotive
Lake Elsinore, CA
951-245-1562
Princeton Auto
I did locate the sensor between the rear seat and the trunk. A pain to get to. I recalibrated the sensor previous to accessing. Code was still present. I removed the sensor, checked wires, connections and resistances and all checked good. Re-installed the sensor and the code was gone. I can only assume the connection at the sensor was compromised.
Thanks for all of your help.
Michael
Return to “Toyota / Lexus”
