2007 Kia Rondo EX 2.7L - AC Specs
- nickscarcare
I just did some ac work on this car and according to the 30/60/90 quick spec it says 1.53lbs r134, in repair it says 15.8 +/- .88. The sticker under the hood says 1.05 lbs. I did call Mitchell and let them know, just to let everyone know the quick spec is off.
Re: 2007 Kia Rondo EX 2.7L - AC Specs
Thanks for posting; I moved it to the product heading as that's more of what its about.
- nickscarcare
I figured if I posted it in the wrong spot you would move it. Thanks!
on occasion i've run into issues like this. what really throws a wrench into the mix is when a hood or door has been replaced and the information stickers are wrong. on more than a few occasions i've been diagnosing with a scanner and get a communication error. start over, get the same, rummage around for the registration with no luck, look for secondary vin strip on pillar post, finally take a long q tip clean all the crapolla (tooth picks, stuck parking tags, crumbs, etc ) to expose the dash vin and find it's different than the one on the door.
