Ford 6.0L Oil & EGR Coolers
liljoe
Re: Ford 6.0L Oil & EGR Coolers
Post by liljoe »
According to the repair info, ( can't remember if it is on Mitchell or Identifix) if there is metal in the inlet of the IPR the pump needs replaced. They are such common to fail that the dealer keeps three of them in stock. This is my first deal on one of these. I mostly work on cars and light trucks but one of my good accounts has three of these trucks so I need to know how to do anything that comes up on these. I hate to sub-let work or send them somewhere else. One thing I found is that you do not have to remove the turbo inlet pipe from the manifolds, you can leave it in place and take the cover off the high pressure pump. Just finished taking it apart and it isn't a big deal. As far as it being leakage, I hope NOT, all the seals on the pipes are new. When I took the pump out I covered the outlet hole and turned the pump then filled the new onew with oil and done the same on it, I noticed a big differance in the amount of oil that it pushed past my thumb( I know this is not much af a test, butI was curious). got to do someother things the rest of the day, will try to get back on it in morn and let yall know how it goes. I also have a few pics of the repair process that I will post to help everyone know what is involved in this apperantly common repair. I know the fear of the unknown was the worst part of this, so far that is!!!!
thx joe
liljoe
Post by liljoe »
IPR valve.jpg (37.41 KiB) Viewed 6552 times
oil inlet.jpg (31.93 KiB) Viewed 6548 times
pump cover.jpg (53.99 KiB) Viewed 6548 times
liljoe
Post by liljoe »
more pics
pump details.jpg (52.46 KiB) Viewed 6543 times
top of cover.jpg (51.47 KiB) Viewed 6542 times
liljoe
Post by liljoe »
turbo pipes.jpg (86.59 KiB) Viewed 6533 times
Doing a VGT solenoid on one tommorow for a surge. Dont have any cool pics! boost gauge jumps around and it surges at lite throttle. You can watch it on the scanner and it is allover the place
liljoe
Post by liljoe »
This truck was doing that a while back and he had replaced the solenoid and it didn't fix the problem. I took the air inlet hose off and the turbo shaft had play in it and I could move it up and down in the housing, not enough to make the fins touch, but you could see the play. He replaced the turbo and it fixed it. Just finished mine and it started in under 15 seconds of cranking, as soon as it hit 450 psi it fired right off.
Nice
liljoe wrote:This truck was doing that a while back and he had replaced the solenoid and it didn't fix the problem. I took the air inlet hose off and the turbo shaft had play in it and I could move it up and down in the housing, not enough to make the fins touch, but you could see the play. He replaced the turbo and it fixed it. Just finished mine and it started in under 15 seconds of cranking, as soon as it hit 450 psi it fired right off.
Ive got no play in the turbo at all so vgt should "hopefully" do it it will be in today
liljoe
Post by liljoe »
How did you come out on the VGT solenoid? BTW, nice updated pic of the kids and yall, was wondering the other day how much they have grown since that other pic. Nice looking family.
VGT went well not problems. I found the air intake temp sensor was not working also reading - degrees just waiting tell monday for it. Thanks yes my kids are growing to fast. Hopefully one can come in here and take over for me someday. I still cannot believe what a can of worms these 6.0L's are
