2001 Cad DeVille DHS - Cluster Issue
mopwrforme
200 Club: Major Contributor
Post by mopwrforme »
the cluster is off line the scanner will talk to everyother module but the cluster visually the tach. works the speedo works it lights up the abs light is on the airbag light is on the alt. light is on. no temp gauge or fuel gauge. when you go into the airbag module or the abs, the codes are for no comm. with the cluster as far as the alt goes its mantaining 13.7v. at this point i pulled the cluster wiring diag. and ck. pwr and grds. i put an engine in this thing apx. 1200 miles ago and have checked all my grds under the hood they seem to be ok. what am i going to need to check this cluster? any input would be great help thanks too all :?: :?: :?:
perfection-automotive.net
Re: 2001 Cad DeVille DHS - Cluster Issue
seperate issue here. it needs a cluster. very, very common in these. if your customer is leaning towards this being your issue have him google "caddy dash cluster".
nickscarcare
Post by nickscarcare »
I agree, I have replaced a few of these in my time.
Probably a cluster, but just check the communication line for continuity. I recently neglected to do this on a late model GM and mistakenly called the PCM bad. There was an open in the circuit. :oops:
mopwrforme
just an update i have cked the comm. wires to the cluster there intact as are the pwr and grds at this point im still waiting for auth. for repair. i think the cost of the cluster is an issue. at this point i almost am ready to let them have it back due to the time its been on hold, untill they can get the cash to fix it. thanks to everyone on great input i get a little hesatant with modules and high dollar elec. componants i cant afford to eat a catty cluster or module thanks to everyone
dorman just came out with a line of clusters.......................
Return to “GM Cars”
