Database corrections?
MarionB2BAuto
Post by MarionB2BAuto »
I am not sure where to put this, so I figured I would post here. Where do we go, or post, if we find an error in the database information for a vehicle? Specifics are that in the "repair" section for a 1st generation (1996 to 2004) Toyota Tacoma with automatic transmission, the database says that the proper refill for the automatic transmission is between 1.7 and 2.5 US Quarts, depending on application. This information is incorrect. Every Toyota in this year range that I have services has required 4 US quarts to get it full. I have tried to locate the information, but have come up short, where Toyota listed that their database was incorrect years ago.
20 Years with General Motors
L1 Recertified
Re: Database corrections?
Since this is about repair information I moved it to that section. Under Repair topics there is a product support link to use. I copied it below:
http://www.buymitchell1.com/form/productsupport.htm
Return to “Using ProDemand”
