Order Of Listing On WIP Screen
MarionB2BAuto
Post by MarionB2BAuto »
I have looked around and have been unable to find an answer to this. As it sits now, when looking at the WIP screen, you have a choice between the list starting with estimates, then invoices, and finally repair orders, or you can reverse this (Obviously it puts things in alphabetical order or the reverse) Is there a way to alter this? I prefer the idea of having Estimates on top, then Repair orders next, and Invoices on the bottom. Can this be done or is is set?
20 Years with General Motors
L1 Recertified
Re: order of listing on WIP screen
i am running 6.4. if i click on the header "Type" once the estimates are on top, then Invoices, then RO's. If i click on the header again I get RO, INV then Estimates. That is my only two options. Unless I make it so one of three don't show up at all.
Yes, it would appear it's coded to sort alphabetically. Poor Invoices are stuck in the middle no matter what you do. :oops:
Clicking Type column would provide A-Z or Z-A sorting as described. In addition to this, the Display button determines record types to display. You are probably set to All and could experiment with the indiviual options provided there.
