Email company
- nickscarcare
Email company
We email different companies the invoices, problem is to email, there has to be a name in the customer name part. Then when you go out of it in the WIP screen is only shows the name, not the company. Is there a way to have this fixed so it recognizes the company name as a field to email and not have to put in a persons name in the name spot? I am running 7.1.7. Right now we have to remember to go back in and delete the name so the company name shows up in the WIP.
Re: Email company
Go to Shop Data and Select Screen View and then under Display Customer or Company name in WIP make sure you have the Company selected.nickscarcare wrote:We email different companies the invoices, problem is to email, there has to be a name in the customer name part. Then when you go out of it in the WIP screen is only shows the name, not the company. Is there a way to have this fixed so it recognizes the company name as a field to email and not have to put in a persons name in the name spot? I am running 7.1.7. Right now we have to remember to go back in and delete the name so the company name shows up in the WIP.
- Shop Data.gif (40.74 KiB) Viewed 4238 times
Re: Email company
Not exactly sure about the email part.
Re: Email company
Why don't you just put a name in there? I haven't dealt with a company account yet that didn't have a human with a name.nickscarcare wrote:We email different companies the invoices, problem is to email, there has to be a name in the customer name part. Then when you go out of it in the WIP screen is only shows the name, not the company. Is there a way to have this fixed so it recognizes the company name as a field to email and not have to put in a persons name in the name spot? I am running 7.1.7. Right now we have to remember to go back in and delete the name so the company name shows up in the WIP.
- nickscarcare
Re: Email company
As I explained, when we go to the WIP screen it only shows "tom" or whatever name we put in there. No longer displays company name.
Re: Email company
I'm on the same version. Company names display fine. You either have a setting issue or a problem with the program. Do you have the display selected as pointed out in this thread?nickscarcare wrote:As I explained, when we go to the WIP screen it only shows "tom" or whatever name we put in there. No longer displays company name.
Re: Email company
Do you have the right ones marked, like in that picture I posted?nickscarcare wrote:As I explained, when we go to the WIP screen it only shows "tom" or whatever name we put in there. No longer displays company name.
- nickscarcare
Re: Email company
I did that this morning and yes I had it set at customer, thanks, I did not know that was for that. So far looks like it works.
