Update 7.3.10
Update 7.3.10
Just updated today. Anyone know all the changes in 7.3.10
Re: Updat 7.3.10
There is a button on the splash screen that tells you
Re: Updat 7.3.10
We're on version 7.3.8 and I don't see a button which lists the changes for 7.3.10. I also checked m1files and, unless I missed it, I didn't see the change log there either.sbebenelli wrote:There is a button on the splash screen that tells you
Re: Updat 7.3.10
I don't believe there are any major changes between .8 and .10. Mostly the dot.net update for Windows. In Manager, under Help, click on check for updates.
- Johnny5
Re: Updat 7.3.10
Re: Updat 7.3.10
This for 7 and 10 or just 10?
Thanks.
I would think all, but they do only really call out 10 in the message.
Regards,
Matt.
Thanks.
Regards,
Matt.
Re: Updat 7.3.10
The issue is Win 10 but will likely trickle down to other operating systems eventually as they get updated.
Re: Update 7.3.10
Well I screwed up always thought of 7.3.10 update as 7.3.1 and figured the 7.3.8 was the higher update, boy was i wrong. Got the the new windows update over night and SE wouldn't work this morning called in and found out that needed the 7.3.10 update, back up and running.
