What Needs To be Fixed In ProDemand
Re: What Needs To be Fixed In ProDemand
Okay, so to get to those items, you'd have to go through this:
2004 Dodge 3500
Here is another it does not say if this is front or rear ring and pinion.
mitch error.JPG (37.62 KiB) Viewed 47867 times
Same; sub-category [boxed in red] confirms Front or Rear for the items that follow once you select:
Mine does not do that. It goes like this on my end. For the 2011 F350.
mitch error.JPG (23.01 KiB) Viewed 47864 times
mitch error 2.JPG (65.95 KiB) Viewed 47864 times
Here is the 2004 Dodge
mitch error.JPG (71.3 KiB) Viewed 47861 times
Okay, had to go back to another PC with SE 7.2.9 to see what you're seeing. So when you get SE 7.3.x in a few weeks it has the views I've shown above.
sbcauto
Post by sbcauto »
I Have Found Since My Last Post That On demand Is A Lot Better. Still Would Like to Print A Larger Wiring Diagram. Thanks
himels
Post by himels »
When attempting to print a wiring diagram, I select the full page and it shows the print preview image on the screen as a Black & White image with a check mark that has to be removed each time if I would like to print in color. I would like to set the default to Color and avoid having to un-check each diagram for color printing.
himels wrote: I would like to set the default to Color and avoid having to un-check each diagram for color printing.
Thanks for posting; inquiry made.
Here is the response regarding printing question:
"We created the current experience because people complained about the cost of color ink cartridges."
timbre4 wrote:Here is the response regarding printing question:
Who would want to print a color wiring diagram in black & white lol
I know, but you'd be amazed how many calls we got.
Maybe make it a sticky setting so that users can choose one and never have to change it? I too find it annoying that I have to uncheck that box EVERY time.
ricmorin wrote:Maybe make it a sticky setting so that users can choose one and never have to change it? I too find it annoying that I have to uncheck that box EVERY time.
If it was a desktop app, it would be pretty simple. I believe the printing attribute in a browser is problematic or we'd have that option. I did hear that it *might* be possible to discern what type of document and print appropriately. (thinking B/W for repair info + color for diagrams as example)
I had a feeling. If it's a one page diagram I pull it up on the 32 inch screen.
diagnostic cart
diagnostic cart
Multi page diagrams are a different story.
I'm the same way. I have a 32" at my tool box. I would rather look at a wiring diagram on that than a small piece of paper.
Return to “Using ProDemand”
